Alky tank leaking around fitting
Slick87gn
142
10
18
Lithia,FL
I tried tightening it but it stills leaks. What do you guys do when the tank leaks around the fitting. ALKYCONTROL kit.
SpeedRacerX
913
229
43
51
Southern NJ
Ok, mine is leaking at one of the brass elbows at the pump. Very tiny drip once in awhile.
ttypewhite
3,179
492
83
46
Toronto
I drilled it out and made my own out of Russel fittings. It's cheaper then buying another one, and much stronger. Just need a long needle nose pliers to hold the fitting from the inside while you tighten it up on the outside tight enough to properly crush the plastic washer to seal any alky from leaking. No more leaks...
Slick87gn
142
10
18
Lithia,FL
I drilled it out and made my own out of Russel fittings. It's cheaper then buying another one, and much stronger. Just need a long needle nose pliers to hold the fitting from the inside while you tighten it up on the outside tight enough to properly crush the plastic washer to seal any alky from leaking. No more leaks...View attachment 332017View attachment 332018Whats the fittings size or numbers so I can order them
marleyskater420
still needs to learn
Aug 14, 2004
1,660
272
83
32
Where mind expansion abounds
What kind of needle nose pliers you have. I can hardly see the corner of the tank let alone a gasket and a nut.
If you don't have long enough needlenose pliers, Harbor Freight has some affordable ones that would do the job.
They have ones up to almost 16"-18" long, with the jaws about 8" in length, with various angled bends for the tips as well.
FWIW the Harbor Freight ones are just as long as my MAC Tool ones, and they work almost as nice. Only difference between the two is how easy it is to open them. Other than that, I use both pairs interchangeably.
Top Bottom
