SignUp Now!If you look at the pictures they look like the same as our ABS units do. I do not think they manufacture that particular bumper filler. That filler is manufactured in FL. like the FG units are. (2 different companies)Not trying to take business away from supporting vendors but has anyone ever used E&K Bumper Fillers?
http://sandkindustries.com/
I will have the GM style Fillers on my site today. There is a slight delay because I am having the speed nuts built new & the rubber push pins built new in with this kit. A Full set front & rear will be $649.95.
Fronts & rears will be available seperate as well.
All pock marks from the originals are removed. No repair work needed. Steel is not bare but an EDP coating. Sorry for the delay I just figured the new hardware will make for the best installation experince.
We will have a set at the Burlington event so you can handle them & compare. I will aslo have a GM unit there for comparison. They will have a alot longer life then the originals.
A Full set fronts & rears will be $649.95.
Anything you paint needs prep. What I was saying is that the gm units needed a lot of prep work for the cost comparitively. Fitment though was dead on with GM & so is the fitment with these.Any brand/source for bumper fillers is going to require prep and paint. GOOD ones shouldn't need much of any fitment work, but even the NOS GM ones come molded in gray.
