OK,
I'm out of ideas here. Car shut off on a test drive after installing the new build.
It has a new Crank Sensor, New Ign Module and Coil Pack. Plugs and Injectors are firing The spark appears a little weak to me. It's wide but it appears a little yellowish, it's definitely not blue.
There is battery voltage at both of the pink black feeds to the ign module.
The base of the ign module is within 3 ohms of of the engine ground post (CEI Ground stretcher).
Plugs are wet with fuel.
Injectors are not leaking.
What am I missing here.
