So my passenger side visor kept falling down, so I bought a new visor bushing...installed it, but that does not seem to be the problem at all.... The darn pin in the mount just spins around easily, so even though the visor bushing is tight with no slip, the visor still falls down because the pin is so loose... How do you fix that??
I thought i might put the thin liquid super glue down the shaft of the pin, or in the little hole in the middle of the spring in the pic attached?? Or try to spot weld the pin to the mount.
