Antenna in the windshield?
Discussion in 'Car Audio' started by Tom Kelly, Oct 4, 2017.
  1. Tom Kelly
    Tom Kelly
    Expand Collapse
    Jun 23, 2016
    64
    0
    Offline
    My 86 came with the electric antenna and it’s malfunctioning AGAIN (despite a rebuilt unit less than three years old). It doesn’t fully extend or retract. Actually I never listen to the radio (optional graphic equalizer setup) but the antenna activates whenever I turn it on to listen to my itunes (using an FM modulator to transmit on the FM band) So two questions:
    1. What is the easiest way to disconnect the antenna motor so it will just stay in one place all the time but still be connected to the radio. I could leave it partially extended all the time)
    2. I am having the car repainted this winter and had planned to put in a new windshield. Would there be any issues if I install a windshield with the built in antenna? I see OPG has them. I am assuming it could be connected to the radio without too much of a fuss. Or not?
  2. Sleeper-6
    Sleeper-6
    Expand Collapse
    May 25, 2001
    1,058
    4
    Offline
    I don't have an answer, but giving the thread a bump since I would like to know as well.
  3. Tom Kelly
    Tom Kelly
    Expand Collapse
    Jun 23, 2016
    64
    0
    Offline
    Just. Heard from my expert in all things Buick and he said the antenna windshield can be installed and the electric one disabled.
  4. Buckshot G/N
    Buckshot G/N
    Expand Collapse
    Nov 2, 2011
    207
    21
    Offline
    What is a Antenna Windshield For Turbo Buick., Years ago the antenna was laid in the front windshield, it that what you are talking about ?
  5. pacecarta
    pacecarta
    Expand Collapse
    MAGNA
    Staff Member
    Aug 1, 2003
    8,500
    557
    Offline
    to deactivate the power antenna motor
    drop glove box down and unplug orange wire at top left side or unplug ant relay at lower right side its screwed to the backside of dashboard
    or underhood unplug the 3wire connector between the ac box and passenger fender
    or at back of radio pull the pink antenna wire pin out of the black plug
    or fix the antenna
    as for windshield embedded antenna i have one on my 87gn ttop race car and have a gm fender which came without the ant hole
    youll need to replace the glass and youll need an antenna lead in from an embedded glass antenna car and drill the cowl for the lead
  6. Tom Kelly
    Tom Kelly
    Expand Collapse
    Jun 23, 2016
    64
    0
    Offline
    Thank you very much. This is very helpful.
  7. buddy
    buddy
    Expand Collapse
    Sep 6, 2013
    733
    116
    Offline
    I had the windshield with antenna installed on my t type when I got it painted and it works great. Good reception.
    • Like Like x 1
  8. buddy
    buddy
    Expand Collapse
    Sep 6, 2013
    733
    116
    Offline
    If you need to see where to drill hole for antenna in cowl I can send a pic
  9. Tom Kelly
    Tom Kelly
    Expand Collapse
    Jun 23, 2016
    64
    0
    Offline
    Just back from Florida and saw this post. A pic would be great.. Do I need the hole drilled before the new windshield goes in or can I do that when I get the at back from paint?
    My email is TJK1947@aol.com.
    Thanks again
  10. buddy
    buddy
    Expand Collapse
    Sep 6, 2013
    733
    116
    Offline
    Just emailed you.
Share This Page
