I have an 85 I'm thinking of selling and not exactly sure what its worth. The engine has been rebuilt about 15K miles ago and was upgraded with some things. It has 36lb injectors, forged aluminum pistons, a high volume oil pump, a new water pump and starter and a new radiator. The transmission was also rebuilt about 20K miles ago with an hd eaton posi unit and 3.73 richmond gears. It also has a transmission cooler hooked up. The exhuast is a mandrel bent 2.5" with ceramic coated headers and euro chamber mufflers. It also has a special switch that I think affects the waste gate that will allow up to 19lbs boost, but I have never used it as I don't take it to the track and use race gas. The car also has a heated 02 sensor. The car has good tires, fat ones in the rear. Dash and headliner are all good. The car comes with pretty much if not all (as far as I can tell) of the parts to convert it to an 87 style setup. Some of the problems include it will have no radio, the interior is in good condition except for the driver side seat has a tear in the upholstery, and there is a rust spot in the passenter side rear quarter. The car has all the components for A/C but there is no belt on the compressor so I don't know if it works. Some of the power lock switches don't work as they should. The car could also use a paint job and needs the rear bumper filler replaced. The undercarriage is very clean. Thanks for any ideas.
