Any way to run race gas without ruining o2 sensors?
turbosam6
My cars suck
I've heard the Max effort can go without an o2, is this true, and if so, how? Any other ways? Thanks for the help!
The ME is a purely open loop chip and does not use the o2 sensor for fueling adjustment. One can simply pull the o2 out and plug the hole whenever desired.
I understand open loop, but how does it know how much fuel to put in? I have an egt, but I can't tune with that at non-wot can I?
See http://members.tripod.com/turboracer/maxeffort/
The chip is user programmable as explained in the above link.
It comes with established defaults and needs very little tweaking right out of the box. The drivability of this chip is outstanding and the programability allows it to be fine tuned to particular combinations.
You will never know it is open loop unless you have to pass strick emissions' testing and that, it will not do. It was originally made for big injectors but it works well with all the injectors it supports from stock up.
