Intercooler
- May 24, 2001
I got this kit from Eastwood's to fix a hairline crack at the driver's side headlight and thought maybe someone else has used it. I did some testing with it tonight and when you mix the powder with the liquid it seems pretty decent! Only problem is the directions say to V shape the crack and fill. Before I do this I want to make sure it flows nicely and does what is stated..... or I will have a V in this area that may ruin the header panel
I think it will work if I mix the two parts fast then use a spreader to fill the V. I have an extension section of the same material that I plan on cracking to test the theory first.
