Absolutely! What needs to be reinforced is the fact that things in the exhaust arena are completely different when turbo charging is used as opposed to what's cool in the N/A (normally aspirated) world.
The turbo does all the work. And uses exhuast gasses to do so. One of the most important things to remember is, THERE MUST BE NO, I REPEAT NO POST TURBO BACKPRESSURE/RESTRICTIONS.
Now, with that said, in the real world that's almost impossible to accomplish, however, there are ways to keep post turbo backpressure to a minimum.
Large piping (as practical)
smooth large radius mandrel bends
straight through (non chambered) mufflers if you're using muffs.
Even with a good flowing exhaust system you can see how much of a difference can be had, particularly if you're running a THDP. Just remove whatever is between the THDP and the exhaust pipe and run it open like that for a little while. Talk about added performance!!
TALK ABOUT NOISE!!!!
Neet turbo whistle too
Closing comment: On turbo'd cars, yes, Flowmaster are a hinderance, any chambered muffler would be.
