Are These Readings Normal (scanmst)
V8killR4U
IVE BEEN HAVING TROUBLE TUNING MY CAR LATELY STILL LEARNING ALOT, HERE ARE SOME READINGS I TOOK AFTER RIDING AROUND IN MY GN TONIGHT. COULD YOU TELL ME IF THESE READING ARE NORMAL, AND IF NOT WHAT THEY SHOULD BE READING AND HOW ITS RELAVENT TO A GOOD RUNNING REGAL. iS THERE A REFERENCE PAGE ON THE NET THAT WILL EXPLAIN EACH MODE AND WHY ITS RELAVANT TO A GOOD RUNNING REGAL. iF MY NUMBERS ARE WRONG CAN YOU PROVIDE A PAGE WHERE I CAN READ UP ON THIS INFO. wELL HERE ARE THE READNGS FOR MY CAR @ IDLE.
O2'S - 847, 859
AF - 04
L8 - 35-36
BAT - 13.4-13.5
INT - 14
BL - 30
MPH - 0
DE OR CLE -159
ATS - 75-83
R - 775-800
TPS - .50
IAC - 26
CC -00
NAL - 00
I REALLY NEED HELP WITH THIS, WHERE DO YOU GUYS GET THESE BASE LINE NUMBERS. IM THINKIN MY NUMBERS ARE REAL OFF COMPAREWD TO WHAT IVE SEEN PLEASE HELP ME:confused:
Your AF numbers look a little low, should be 6~7 at idle & need the WOT #'s as well, should peg out at 255. The TPS is high, set the idle # to .44~.45 & you need to check the it at WOT as well, just turn the key forward (don't start the car) and mash the go pedal. :)
Doug C.
