SignUp Now!....snip....Reason I Bought The System Is Because I Can't Get The Car To Stop Detination Around 20psi Spits And Sputters At High Boost! Thought More Fuel Would Help!! Thanks Again For All You Help!!!!!!!!!!!
Thank You For Your Input!! Fuel Press Does Rise As Boost Goes Up, Scan Tool Does Show Lean O2 Drops To 0 Volts, I Will Look At The Spark Retard I Gess I Was Just Assuming It Was Retarding The Timming But Not Sure Thanks Again For More Great Tips!!!!!!! Looking Forward To Getting This Thing To Run Properly!
