-----Next week at school we are going to START installing the ATR 3" dp(internal wg)..
I have LOOKED on "OTHER" sites, But the information was "WEAK"!!!!!! So I going to ASK the PROS.
-----QUESTIONS----
1.DOES a gasket install BETWEEN the DP and the TURBO housing?----if SO...where to get? If NOT...WHAT is used to SEAL mating surfaces????
..... CLEARANCE PROBLEMS???
2.NO aftermarket headers are on the GN---STOCK(what ever came from the FACTORY)....Will there be a clearance issue with the Stock Exhaust?
3. Body mount are in GOOD shape (no unevenness on 4 corners)--fenders lines/gaps correct--body bushings look good...(what I can see)........Motor mounts...I THINK are O.K...not MUCH movement under SHARP rap-of-the Throttle.
....REMOVAL of STOCK DP????
4. Remove ELBOW????? What to WATCH-OUT for?.......DownPipe???? OR REMOVE-- BOTH TOGETHER?
....INSTALLING DOWNPIPE...
5.What is BEST way to get DP "SNAKED" into motor compartment???? WHAT ISSUES---/WORSET/BEST......EASIEST..... Top....Bottom or ????. WHAT OTHER part(s) needs to be removed (if any) to get DP in CORRECT position to align with Turbo.
6. ANYTHING that NEEDS to be done to the "puck" in the DP... BEFORE installing---antiseize...OR.???
ANYTHING ELSE?????
THANKS
SORRY for the long QUESTIONS, But I DON'T want to SCREW-UP!!!!
-----QUESTIONS----
ANYTHING ELSE?????
THANKS
