I have an atr wastegate hooked up through the wastegate solenoid. Is this correct or should I not use the solenoid? With the atr adjusting screw all the way out, I was getting about 12 psi of boost. Now with it nearly all the way in, I'm getting about 16 psi of boost. I'm planning on installing alkahol injection and will need more boost. There's not much adjusting left for any more.
