Mar 14, 2004 #1 B B.C.Rich New Member Joined Mar 1, 2004 Messages 3 I've got an 86 GN with a digital dash and don't know where to wire the green signal wire onto from the tach.
Mar 14, 2004 #2 H Hognose Member Joined Jan 30, 2003 Messages 558 There should be a green spade plug coming off the alternator wiring harness. Attach a plus to the green wire from the tach and hook up the power and ground and you should be good to go! Matthew
Mar 14, 2004 #3 V Vendor Defendor Out the window Joined Nov 25, 2002 Messages 3,537 http://community.webshots.com/photo/95776453/97923267crLTbD see that green connector right behind the alternator there? try and find that and plug into, thats your tach plug in. good luck
