Sep 2, 2006 #1 A aquickv6 New Member Joined Sep 4, 2004 Messages 374 I have seen some great looking installs of the Megashifter in the factory console. What part number for the shifter are you using for the factory console? Thanks
Sep 2, 2006 #2 PaCemkr86 WFO Racing Staff member Joined Jan 19, 2005 Messages 4,368 here is mine with the B&M hammer
Sep 2, 2006 #3 M Mad_Trbo Active Member Joined Jun 10, 2005 Messages 1,033 Wow that is nice and clean looking. That's a ratchet shifter right? Ever have any problems with it hanging up between gears? I keep getting conflicting reviews with regard to ratched vs non ratchet shifters.
Sep 2, 2006 #4 PaCemkr86 WFO Racing Staff member Joined Jan 19, 2005 Messages 4,368 no problems here, im running a TH400 with reverse pattern shifter and a transbrake
Sep 2, 2006 #5 L lazaris Active Member Joined May 25, 2001 Messages 1,497 PaCemkr86 said: no problems here, im running a TH400 with reverse pattern shifter and a transbrake Click to expand... How did you hook up the column ?
Sep 3, 2006 #6 PaCemkr86 WFO Racing Staff member Joined Jan 19, 2005 Messages 4,368 its not hook up, i removed the linkage
Sep 3, 2006 #7 L lazaris Active Member Joined May 25, 2001 Messages 1,497 Ok Thanks. Do you manually move the column then?
Sep 3, 2006 #8 PaCemkr86 WFO Racing Staff member Joined Jan 19, 2005 Messages 4,368 only when i need the revese lights
Sep 4, 2006 #9 M Mad_Trbo Active Member Joined Jun 10, 2005 Messages 1,033 Reverse lights Does the megashifter not have the solenoid provision for reverse?
