back em down
KC87
208
190
43
you got that right earl , I have a roll master waiting, but I thought I read somewhere you went back to stock nylon ?
Did mine at about 130k with all stock parts, expected to see some of the nylon teeth missing but it was like new, not even a chip. 46k later and so far its good.
earlbrown
runs with scissors
May 26, 2001
7,294
1,435
113
48
lagrange, GA
I stick with stock nylon on flat tappet cams. I like them because they're quiet, can use the tensioner, and don't piss off the knock sensor. The downside is they are pieces of shit and have to be replaced every 10 years or 125,000 miles. :)
Rollers are forced to move up to the double roller. Stiff springs and only 12 valves make for a lot of ''cogging'' when turning the cam. That can really beat up on a timing set.
With your Rollmaster, you'll need to grind the goofy flap off the backside of the cam sensor bore when you get the timing cover off.
grass doctor
1,524
698
113
44
saint augustine fl
see now I was wondering about all that , thx for your insight , always much appreciated !!!
