brakes
those are some nice brakes. But what you have to always keep in mind that it is the power booster that makes the brakes, it is the line pressure that stops the car. Subjects to consider, what is your current setup, does Baer make the system bolt on ready for that vehicle, because otherwise you might not have the brackets to do it, do you want front or all wheel disc? And I bring up the importance of the booster because i have worked on many of the G - body cars and noticed that the powermaster unit is prone to problems, I am actually from a brake shop called Power Brake Service, which is why I know a lot about the brake system of your car. But we have seen many people put on these 7 inch units that are in all the magazines, and they did little to nothing to help their braking. We have been putting more powerful seperate booster and master systems on these cars, but one of the best things we have been doing is installing this unit called the hydroboost, which is a hydrailic brake that runs off the power steering pump rather than the vacuum from the manifold, or in the case of turbo Buicks an electric vacuum pump. The advantage of this is that you can run any camshaft you want and not worry about any loss of vacuum. you can give us a call up and we can explain it to you more but, we are a supplier of Baer and Wilwood, who recomend customers to us all the time since they don't deal with boosters. our number is (800) 504 - 1060 and ask for Bob or Matt
