Paul Clark
- May 22, 2003
IAC re-set. Go by rpms, correct?
This, however, may vary depending upon the chip and injectors. (?)
Should I go by the IAC index instead of the rpms?
High 20's are good, correct?
Assume this is indicated by the # number and not the %. (Tlink)
Or do you go by the MAF GPS #?
When do you take the readings?
My car goes into closed loop well before it reaches operating temp.
The numbers keep changing at idle.
At present, I get the following at a temp of 165 and rmp of 875 -
IAC index 120-121# and 7 or 8%.
MAF - 6GPS.
TPS - .40, but it sometimes drops to .38.
Am I close?
Sorry so long, but I'm confused and I'm running out of paper clips doing the IAC re-set thing.
Many thanks.
MAF - 6GPS.
Am I close?
Many thanks.
