TurboTnZ06
Go on red!
- May 7, 2002
I pulled the cam sensor cap to replace it, as I determined that was the cause of my "no start" condition. Unfortunately, I don't think the cam sensor interrupter ring and shaft should spin freely
I pulled it out and it seems fine. However, I think I need to pull the cover to see why it isn't spinning that since the HV cover cam sensor shaft just has a short drive down to the main gear. Oh, how I don't want to tear this engine down...
Basically what happened is that on my way home a few weeks ago, I got on the gas to about 10 psi boost. Then let off and tried to drive normal. However, since I just lost my cam input at that moment because the gear was no longer driving the cam sensor, the car went into batch fire mode to stay running since there was no more cam signal. No SES either, none at all. It ran terribly except for full throttle. Perhaps the 60# motrons weren't what batch fire was ready for. So I made it home. No warning lights, no funny knocking sounds, no indicated knock retard, but alas, I'm sure now that I had little to no oil pressure during my full throttle blasts as the only way the car would accelerate and not backfire. I wonder if the Mobil 1 helped get me home? The TE45a is solid, no play in/out.
I assume there is a roll pin that shattered allowing the gear to spin on the shaft? Anyone go through this before? I searched and searched and can't find much info at all, let alone any pictures of the internals of a PTE HV front cover, so I know what to expect when I tear it down. gnttype.org only shows a stock cover
I might as well pull the freakin engine out...
...again
TIA
TIA
