Originally posted by TurboShane
OK, here is the deal I have bent two pushrods now witch never fixed my backfire problem, so I had the motor tore down by my uncle who is a gm mechanic. Here is what we found a blown headgasket between 1 and 3 and a couple other spots, a pushrod that looked like a pretzel. The intake valve on #1 was not bent but was very tight to move. Cam is fine and the lifter is fine. Where do I go from here? The valve stem was scored some and was very tight but did move do you think this could cause the pushrod to bend? Oh and the plastic button was there but looked like it recieved some stress because it was pushed up some was not flat like the rest of them. Thanks
