May 11, 2004 #1 S Shane Moderator Joined May 28, 2001 Messages 1,715 Ok guys, where did you mount your translator plus?
May 11, 2004 #2 G GNut Member Joined Aug 8, 2001 Messages 195 Where did I mount it?? In the passenger compartment in the center console. You can use the extender harness avaialble or just lengthen them yourself.
May 11, 2004 #3 B Benched Member Joined May 25, 2001 Messages 173 I put mine on the back side of the glove box with velco.
May 11, 2004 #4 D Dan Thompson New Member Joined May 25, 2001 Messages 778 Check out the next to last picture on my website. With the extende cables you can go thru the fire wall under the steering column, best seen from the inside, and then over to the glove box.
