BIG PARTS LIST, Updated 12/27, more parts added
Intercooled88s
Moderator
Kenne Bell valve covers $100
Kenne bell deep oil pan with pickup for 20 bolt pan $100
A pillar dual pod gauge holder $30
A pillar single pod gauge holder $20
87 GN Electric fan $50
Radiator hold down(plate on top that hold radiator and electric fan) $40
87 GN short block ran good when removed $800
Lighted 87 turbo Limited dash plaque $50
New Tan front floor mat's, they have a Turbo 6 embroidered in them $40
New Cam Position sensor CAP(just the top) $40
Set of (4) 87 GN wheels in good condition(but not perfect) with center caps and lug nuts $500
Complete 86 T-type front clip $800
GN front bumper $100
Vac brakes with pedal $65
1 86-87 T-type wheel center cap $30
New Sealed Power ring set(.030, never opened box) $40
K&N cone air filter with sensor in neck $20
87 GN seat belt set $100 for all 10 seat belts
Rear seat brace kit(Kirban brace kit) $35
Front lower brace kit $30
Front upper brace kit $25
T-type header panel $150
T-type header panel with hole on top filler $150
GN spoiler (GM , 3 pieces) $175
Racing seats(2) $100 (I won't ship these)
Fuel cell $60
Shifter with T handle $50
Concert sound 2 lower door panels(gray, 87 T-type) $100
steering column(floor shift car) $100
Rear bumper fillers $80
Blackout headlight bezels $50 for both
blackout marker light $50 for both
Amber bumper lights $30 for both
Powder coated 87 main accessory bracket(big alum bracket) $70
Tranny cooler $25
ATR Ram Air box with K&N built into it(the box is made of alum) $40
ATR big front sway bar $100
Tubular rear lower control arms $80
NEW Richmond 3.73 gears $90
87 GN Engine 82k complete $2200
87 BRF tranny $500
ENGINE PARTS:
AC compressor(84-85 AC compressor) $40
AC compressor(86-87 AC compressor) $60
AC lines(86-87 or 84-85) $40
Adaptor(86-87 oil return to block, brass adapter,screws into block in front) $20
Adaptor(85 Turbo to intake adaptor) $40
Adaptor(Oil cooler adaptor with nut) $30
Air Cleaner scoop(86-87 Scoop for airbreather) $20
Air Cleaner assembly(86-87) $25
Air Cleanerassembly(84-85) $20
Alt.(86-87) $60
Alt.(84-85) $30
Balancer(Turbo harmonic balancer) $80
Battery cable guide(Small plastic guide that holds the posi bat cable to the lower front cover) $20
Block(109 Block) $300
Cam position sensor just the lower part(no cap) $30
Cam position (sensor with cap) $65
Chip(stock 86 chip) $30
Chip(stock 84 chip) $20
Coil pack(84-85) $40
Coil pack(86-87) $40
Control module(84-85) $50
Control module(86-87) $70
Connecting rods(2 dot) $40 a set of 6 or $10 for 1
CONVERSION (84/85(Hot Air) to 86/87(Intercooled) conversion parts(all the original GN parts you need to convert
over from 85 to 87) $1500
Crossover pipe(84-85 Exhaust crossover pipe) $35
Crossover pipe(86-87) $45
Dip stick and tube(86-87 dipstick and tube) $40
Dip stick and tube(84-85 dipstick and tube) $30
ECM(85-85 ECM) $40
ECM(86-87 ECM) $70
Elbow(84-87 Turbo elbow) $25
Flex plate(84-87 Turbo flex plate) $25
Fuel rail(84-85) $25
Fuel rail(86-87) $45
Headers(factory Exhaust headers,both sides)$100
Heads(stock 8445 heads needing rebuild) $40 a set
Injector harness(84-85) $35
Injector harness(86-87) $40
Intake manifold(86-87 Lower intake manifold)$150
Intake manifold(86-87 Upper intake manifold)$35
Intake manifold(84-85 GN intake) $40
Intercooler $45
Intercooler brackets both for $50
Intercooler fan $40
MAF(86-87 MAF) $80
MAF(84-85 MAF) $40
Main accessory bracket(86-87,the big alum. one) $70
Main accessory bracket(84-85) $40
Motor mounts(Engine frame mounts) $35
Oil pan(Turbo oil pan) $35 each
Power steering pump(86-87) $70
Power steering reservoir(86-87) $30
Pulleys(86-87 underdrive pulleys(crank and alt)) $35
Pulley(86-87 Crank pulley with adapter) $30
Pulley(86-87 Water pump pulley) $25
Pulley(86-87 Alt pulley)$15
Throttlebody(84-85 Throttlebody with TPS,IAC motor,vacuum manifold) $40
Throttle bracket(86-87 Throttle bracket) $50
Throttle bracket(84-85 Throttle bracket) $20
Throttle cable(86-87 Throttle cable) $30
Throttle cable(84-85 Throttle cable) $30
Timing cover $35
Valve covers (84-85) $30
Valve cover oil filler tube(86-87 tube and cap) $20
Wire harness(84-85 engine wire harness) $100
INTERIOR:
Arm Rests( grey, red, Maroon or blue arm rests) $20 for 2
Arm rest(Light sage green arm rests(these are the rare light green color)) $30 for both
Concert sound 2 lower door panels(84 GN) $80
Console shifter plate(Plate on console that goes around the shifter)$25
Console (87 GN)$150
Dash pad no cracks(grey or Maroon) $100
Dash pad(Maroon dash pad, no cracks) $100
Dash plaque(87 GN) $90
Door panels(85-87 GN lower door panels) $60
Door panels(85-87 T-type grey lower door panels) $40
Door panels(85-87 T-type Maroon lower door panels) $40
Door panels(85-87 T-type Blue lower door panels) $40
Gauge cluster(Analog) $60
Gauge cluster(Digital) $100
Light sage green seat belt guides $25 for both
Light sage green seat belt upper bolt cover, triangular shaped trim piece $20 for both
Map light $20
Radio(Stock GN radio, no EQ) $50
Sail panels(Grey interior panels around the quarter windows) for T-top car $40 for both
Sail panels(Grey interior panels around the quarter windows) for Hradtop car $40 for both
Seats(87 GN Front bucket seats need recovering) $150
Shifter $35(84-87 GN, needs T handle)
Steering column(grey and shifter on the Column) $100
Steering wheel (Grey and in excellent condition(not redyed or recovered) $300
Steering wheel(good to have recovered) $40
Steering wheel(Tri shield GN horn center $40 no ring)
Steering wheel(T-type horn center $30 no ring)
Steering wheel(T horn center $30 no ring)
Surround(Gauge surround) $30
Surround(radio surround) $20
Third brake light(Grey, red Maroon, or blue Third brake light)$20 Each
T-TOP trim around the t-tops on the inside of the car in, Maroon, or grey , all 6 pieces $100
Visor(Nice blue passenger visor with lighted mirror) $20
Body Parts:
Blackout(Front windshield blackout trim(3) )$40
Blackout(rear window blackout trim(3) )$30
Blackout(Trunk Lid blackout trim piece) $35
Bumper(GN Front black bumper) $100
Bumper(GN Rear black bumper) $70
Bumper reinforcement(Alum. Front bumper reinforcement)$90
Bumper reinforcement(Alum. rear bumper reinforcement) $70
Grill (86 T-type grill) $50
Grill(85 GN grill) $60
Grill Emblem(85-87 T-type grill emblem) $15
Grill emblem(87 , says "Buick") $15
Fenders(84-87 GN fenders(GM)) $80 each
Lock set(all 3 locks with key) $60
Quarter windows with blackout trim $80 for both sides
Rear spoiler(GN) $200
Tail lights with blackout trim $90
T-tops(86-87 GN locking T-tops) $150 a set
T-top black trim that the t-tops rest on(sort of L or boot shaped) $50
T-top boot shaped plates that the t-tops lay on $60
Mirror(Drivers mirror) $20
Mirror(Passenger Mirror)$20
Windshield blackout trim(3) $40
Windshield chrome trim(3) $30
Wheel wells(Turbo plastic wheel wells) $80 each
Any other blackout piece e mail me I have them all
Hood(GN hood) $95-$150
Hood Scoop(GN Hood scoop, cut from a metal GN hood) $50
Misc:
Antenna( black manual antenna complete with mast, base and nut)$35
Antenna base nut and spacer for Power antenna with black trim $10
Fuel pump hanger/sender $80
Gas Tank(Turbo gas tank) $40 WON'T ship pick up only
Heater box(Complete heater box, For AC car) $100
Hydrobooster brakes $100
PowerMaster(complete unit) $170
PowerMaster to firewall adaptor(bracket) $30
power trunk mechinism $20
Rearend housing for 8.5 in a G-body $200
Steering box(87 GN Power steering ) $35
Sway Bars(GN sway bars) $25 each
Transmission cross member $40
Transmission(BRF tranny $500)
Tranny dip stick tube $40
Transmission oil pan(Stock 200 4r tranny pan) $25
Valve body(BRF valve body $200)
windshield wiper assembly $15
Wheels(86-87 GN wheels)good for cores all 4 for $100
E mail me at Fortune628@aol.com or Bobhebert574@aol.com
My phone # is 413 563 8819
What condition are the rear bumper fillers in? Are they original or fiberglass? R.B.
PM'd you also.
What kind of shape is the gas tank in, inside and outside particularly in the under the strap area?
Is it off the car already? I need one quickly. ;)
What part of Western Mass. for pickup?
TIA.
rear seat braces
could you send me some pictures of the rear seat braces?
is it the kirban part#1586, if it is i will take them
let me know
thanks
TIA.
Got your e mail and e mailed back to you.
p.m. on the :
Headlight Bezels
84 Coil Pack
84 Control module
Rear window blackout trim
trim
I was wondering about the door blackout trim on a pillar price and condition and how much for shipping to california area code 93445 thanks....
