Car was running better than it has in weeks, then at work today, i changed the oil and trans fluid and thats where the trouble started. After refilling fluids, i disconnected the ecm, cranked the engine for about 10 secs then reconnected and when it fired up the car ran like absolute crap!!!! when i gave it throttle, it stumbled initially but sounded fine after the stumble. it almost sounds like there is a horrible exhaust leak but there was none before......then while driving the car home, it sounded like a motorcycle out the tailpipes, would take any boost, and the car would hesitate when the converter locked up. my vaccum numbers used to be 18 at idle in park and 14 at idle in drive. now they are 16 at idle in park, and 11 at idle in drive(with a nasty hesitation. when i got home, i hooked up the scanmaster and everything was normal as usual, except the blms were at 145,w hich im assuming means lean???? i am really lost here, i checked all vaccuum hoses and sensors and i cant find anything. would this seem to be a trans problem or an engine problem? any help at all would be appreciated. once again, everything was completely normal before the oil and trans fluid changes........any other info needed, please ask..
