billet roller cam ??
TurbosTeve
anyone know if I would run into problems with a billet roller setup with 1.65 ratio T&D rockers? Stock heads. Is there a clearance problem between the pistons and valves? I'm looking at the comp cams 206/206.
Have set up a few motors with that combo and no problems. Have that cam in stock if you need one.
thanks for the quick response. do you have the whole kit with lifters (885's) and springs, chain and gears etc.
