JDSfastGN
- Jun 16, 2001
Well yesterday I romped on it down a back road, only through 2nd gear. 17 psi, mostly 110 in the tank, no knock on the scan tool and didn't hear any rattle. While coasting down I saw white smoke pouring out the exhaust. I pulled off and turned the car off. Stupidly I wanted to make sure it was wasn't oil smoke, so I tried to fire it off just for a second, and with the water in the cylinder it kicked back and cracked my starter. I towed it home and 5 out of the 6 cylinders were filled with coolant. So I pulled the motor to make sure I didn't bend any rods when it kicked back like that. Well I got it out and torn apart no probem. But my headgaskets do not look bad at all. There was no oil in the coolant and no coolant in the oil. The rods all look good as well. The gaskets are felpro 9441PTs, ARP bolts that I tightened down at 10# increments, and loosedned a 1/4 of a turn and retightened 3 times over a 2 day period to 85 #s.
http://www.ls1camaro.net/freehosting/headgasket1.jpg
http://www.ls1camaro.net/freehosting/headgasket2.jpg
http://www.ls1camaro.net/freehosting/HG3.jpg
http://www.ls1camaro.net/freehosting/HG4.jpg
I'm guessin the bolts stretched and lifted under boost allowing the coolant to find its way to the cylinders but I just don't see it. Just last weekend I had it 23# of boost with the same gas and had no probs. I figured with 110 in the tank and only 17#s of boost and a street chip I would be just fine
I usually run 16-17 on pump gas with no detonation at all. The plugs were all brown but covered in antifreeze.
