Hi All,
Used TEC technique to try to lower BLM of ~143. Found leak between the THDP and Turbo. Will this cause the BLM to huver around ~143?
I doubt this is the culprit since the leak is basically after the turbo and 02 Sensor.
Have done as much as I can to fix vacuum leaks.
Thanks in advance,
Thanks in advance,
