irrompible
- Aug 13, 2003
The problem is only at idle. Any sort of throttle and they jump right to ~128, let off and they instantly go to 150. I'm pretty sure the problem is a vac leak. The only possible one I've found is near the back of the vac block itself. I found it by putting a piece of vac line to my ear and going around all the seals and gaskets. The carb cleaner trick didn't seem to pick it up, so I don't know how serious the leak is, but I'm assuming it's little. Would this cause the blm's to instantly go from 150 to 128 and back to 150 or would it take a bigger leak? Thanks for any help you guys can offer.
