Blue smoking problem
Haynesie
Car will blow Blue smoke while in park and neutral real bad, but in drive their is nothing blue coming outta the tail pipes, even under hard throttle...aany thoughts as to why this is happening...i suspected a bad turbo, but i really dont konw based on this new occurence.
if it just does it at start up its the valve seals. if it does it all the time , probablly the turbo. if its the turbo you will know when it lets loose.:D
well if the car is running in park, then it does it all the time, like i can drive it and their will be little smoke, and the turbo still boosts as high as it did before, but even after running it for a while in drive with no blue smoke, as soon as i put it in park boom blue, but again im not noticing any turbo failure. If it is the valve seals, how do i go about replacing them?
