o.k., for the past 4 days i've been playing with the car. i have alky on it and the boost is 21-22 psi in 1st, 2nd, and 3rd. when i hit 4th gear the boost ramps up to 24-25 psi and the car pulls even harder. i'm not complaining because it's not knocking, but i would like for the reverse to happen. high boost in 1,2, and 3 and low boost in 4. i put 6 turns in the rod and the stupid thing wouldn't budge past 22 psi. also, am i pi$$ing in the wind trying to run alot of boost on a stock turbo. yes, i had to take the 54 off because it ate some plastic from one of the couplers on the inlet pipe.
is my wastegate hole on the turbo to small or something?
