just because the chip
just cause the chip says 22 pounds of boost does not mean you get 22psi, you still have to move the wastegate rod manually, or you prolly have a bad bleeder selenoid, also make sure you have good gas before running high boost and high timing, the motor could be knocking pulling off boost and timing thus the boost surge.
