Boost Tap Location
fastjack1
I have a 1/4 inch hole tapped into the doghouse for a boost line to the gauge. Willthis pass the TSA inspection for stock appearing, and if not, what is an acceptable place to tap into?
There is nothing in the rules stating where the tap comes from so I would assume you are fine but to be safe you better get an answer from the man himself. I am sure Richard will see this and post when he gets time.
Bryan
