Pronto
No amount of evidence will ever persuade an idiot.
- Dec 9, 2002
I installed my BstC yesterday. I have a few issues that I'm trying to figure out. First, with the unit set to off, the Active light is dimly lit. Should that happen? Second, I tested the TPS turn on point. With the unit on, if I set the control knob to the min dot I get no buzzing all the way to the floor. As I turn the knob up to the first dot beyond the min dot I get buzzing. If I go beyond the third dot the buzzing stops. There is no buzzing if the knob is set at 1/2 to max. The active light comes on at about 1.5 volts with the knob set at anywhere. Should there be buzzing at those higher settings doing this test? Also I noticed the Active light gets brighter as the knob is turned up. Should that happen? All switches are set to off. I tried jiggling the wires to see if any happened different but nothing changed. Thanks.
