- Aug 11, 2001
I need to make room, All these parts must go! I have plenty of pictures but limited to the amount of pics I can post. Just LMK what part(s) you're inquiring about and I will send them to you. Prices have been reduced to offload them but i’m opened to offers. PLEASE do NOT waste MY time, serious buyers only, PLEASE!!! Don’t hesitate to ask questions if you have any. Prefer Local pickup for the **bigger- heavier items. Local pickup is Oceanside (Long Island), NY 11572
If marked Shipped, price is to the lower 48. PayPal F&F, Add 3.5% if paying Goods and Services.
5– **Stock Crankshaft- cut .010 mains & .010 rods (needs to be cut)_ $100
6– **Stock Crankshaft- cut .020 mains & .010 rods (needs to be cut)_ $75
7– External Harmonic Balancer_ $125
12– Power Steering Reservoir- OEM left hand thread with chrome cap_$135 shipped
15– T Type Horn medallion with rubber_$80 shipped
16– **84-85 Hydroboost Brake Booster (not sure of condition, was sitting for a long time)_$40
18– 2004R Trans Pan with drain plug (not the best weld job)_$30
24– Spark Plug Wires- Taylor Thunder Volt 50 (one bad wire/boot)_$30 shipped
_SOLD_1– Turbonetics 6965 BB Turbo in great shape, large compressor housing with 4” inlet, 2.5” out, T4-4 bolt exhaust header flange with 3.5” V-Band exhaust out (less than 3k miles)_SOLD_
_SOLD_2– Boost Leash Kit with Dual Clipper boost solenoids, works perfect. Also comes with mounting bracket, quick disconnect fittings and some vacuum lines (less than 3k miles)_SOLD_
_SOLD_3– Moroso Dual Breather Oil Catch Can/Tank (Dual -12 AN bungs and drain plug) fits snug in the battery tray of a g-body (less than 3k miles)_SOLD_
_SOLD_4– Precision Turbo- PTE Turbo Saver Oil Relocation Kit (needs new filter_ less than 2k miles)_SOLD_
_SOLD_8– Diamond Pistons (21403-6) 40 over with rings and pins (less than 3k miles)_SOLD_
_SOLD_10– 3x Billet Caps & ARP Main Stud Kit (USED)_SOLD_
_SOLD_11– 86/87 Coil Pack, Module, MSD Spark Plug Wires, bracket and thermal boots (as seen in pics, USED in good condition) with custom plate_SOLD_
_SOLD_13– PAC ALKY Control parts (only what's in the pictures)_SOLD_
_SOLD_14– Driveshaft Loop_SOLD_
_SOLD_17– 2004R Sonnax Servo Kit (less than 3k miles)_SOLD_
_SOLD_19– Comp Cams 212-212- cam gear has some wear, not sure if it can be repaired (make offer)_SOLD_
_SOLD_20– Dennis Kirban X-Brace_SOLD_
_SOLD_21– Ram Air- Fiberglass Canister and ds air dam (no hoses or scoop, only the 2 items)_SOLD_
_SOLD_22– Kenne Bell Ram Air with KB Plastic canister, filter and ds fiberglass Air dam that needs some fiberglass work to look presentable (needs hose)_SOLD_
Buick Grand National, Turbo Regal, T Type, Turbo T, G Body
86/87 Buick Grand National, Turbo Regal, T Type & Turbo T Performance Parts:
