Burnt directs with dual feed?
Discussion in 'Transmission Talk' started by 77 cruiser, Aug 11, 2017 at 5:07 PM.
  1. 77 cruiser
    77 cruiser
    Expand Collapse
    May 24, 2001
    1,206
    10
    Offline
    I tore my trans down to take a look cause I had it out due to converter issues.
    Found the directs were burned & steels hot spotted.
    Would a slight bind on the 2-3 cause it?
    Don't ask what the press. was, I never checked, thought they would be good they were 270 with the same pump before.
    Didn't have the 3-2 valve blocked then I do now.
  2. Ttype6
    Ttype6
    Expand Collapse
    Aug 17, 2004
    2,901
    154
    Offline
    Did it have a slight bind?
    What servo?
    Did you install stiffer direct return springs?
  3. 77 cruiser
    77 cruiser
    Expand Collapse
    May 24, 2001
    1,206
    10
    Offline
    First servo was a 200C 112 I think, it had a noticeable bind. Put a GN servo in & had a very slight bind but slightly softened the 1-2 & 2-3.
    I put in 8 extra springs inside the factory ones.
    Should add too that I'm only low 12's with a 4200 lb. car.
  4. Ttype6
    Ttype6
    Expand Collapse
    Aug 17, 2004
    2,901
    154
    Offline
    Do
    Do you know if you have a GN servo return spring/the small spring?
    #4 Ttype6, Aug 11, 2017 at 11:01 PM
  5. 77 cruiser
    77 cruiser
    Expand Collapse
    May 24, 2001
    1,206
    10
    Offline
    Yes I have one probably not the stock one.
  6. Ttype6
    Ttype6
    Expand Collapse
    Aug 17, 2004
    2,901
    154
    Offline
    If it's not the stock one,it is probably weaker than stock. The bind is caused when the direct clutches apply too fast and the servo releases too slow. The easiest thing to do is speed up the release of the servo. Call Dave at Turbu Buick Performance and get a stronger return spring from him.
    Have you run the trans since you did the 3-2 mod. This mod might help your problem.
  7. 77 cruiser
    77 cruiser
    Expand Collapse
    May 24, 2001
    1,206
    10
    Offline
    No I haven't, run it need to get clutches for directs & get the conv. fixed.
  8. Ttype6
    Ttype6
    Expand Collapse
    Aug 17, 2004
    2,901
    154
    Offline
    You'd be doing yourself a favor if you got your clutches,steels,and new/stronger than stock backing plate from Dave also.
  9. 77 cruiser
    77 cruiser
    Expand Collapse
    May 24, 2001
    1,206
    10
    Offline
    I think I will the pattern is on the outside so the plate is probably bowing.
  10. Ttype6
    Ttype6
    Expand Collapse
    Aug 17, 2004
    2,901
    154
    Offline
    It absolutely is.
  11. Ttype6
    Ttype6
    Expand Collapse
    Aug 17, 2004
    2,901
    154
    Offline
    Dave's billet direct apply piston is another part of the puzzle.
  12. bison
    bison
    Expand Collapse
    Moderator
    Staff Member
    Dec 19, 2005
    16,477
    1,232
    Offline
    A slight bind won't hurt the clutches. Here's the ultimate direct clutch setup for a 200-4r. .100" steels in all locations with the nice apply ring and ultra strong ultra flat 4140 pressure plate. .100" steels should always be used here. The plate can be machined to your desired thickness. I can offer the plates in .250" 4140. if you think you need it though the 3/16 4140 has proven strong enough. Of course the direct oil circuit needs to be solid. No clutch setup will overcome leakage or inadequate pressures but these parts will allow a very very consistent apply and the pressure plate won't deflect with high pressures and dual feeds. Message if interested. [​IMG][​IMG][​IMG][​IMG]
    #12 bison, Aug 12, 2017 at 5:33 PM
  13. 77 cruiser
    77 cruiser
    Expand Collapse
    May 24, 2001
    1,206
    10
    Offline
    I have a billet piston now. Just have to figure out what to do. Thanks for all the help so far.
  14. bison
    bison
    Expand Collapse
    Moderator
    Staff Member
    Dec 19, 2005
    16,477
    1,232
    Offline
    [​IMG]
    Over 50 hits at mid 9 sec power @ 3700lbs on this one and the output shaft is twisted again. These are all going right back in
    • Like Like x 1
  15. David Husek
    David Husek
    Expand Collapse
    Mar 16, 2007
    861
    171
    Offline
    The problem I see is you are using alto clutches which will always burn as you see them and a bad calibration on top of that. The bind will cause some heat in the clutch pack but not enough to cause any problem. No clutch pack is magical or ultimate and will make your setup live. Period. It all has to do with the complete overall calibration and quality of seal for the complete transmission to live. Give me a call and I will help make your dual feed calibration work correctly for your application.
    #15 David Husek, Aug 12, 2017 at 8:31 PM
    • Like Like x 1
  16. 77 cruiser
    77 cruiser
    Expand Collapse
    May 24, 2001
    1,206
    10
    Offline
    Those look good Bison.
    Thanks David.
  17. Otto J
    Otto J
    Expand Collapse
    May 31, 2001
    7,787
    25
    Offline
    One word of advice. If you have this trans behind a V* with a carb or throttle body you best get a pressure gauge on the trans and be sure as hell you have proper line rise.
    A V8 needs much quicker line rise with throttle and they sell parts that will aid in making this happen.
    Seriously get a gauge on this trans and see what it does.
    (If you haven't already)
    • Agree Agree x 1
  18. 77 cruiser
    77 cruiser
    Expand Collapse
    May 24, 2001
    1,206
    10
    Offline
    I will when I put it back in.
    #18 77 cruiser, Aug 15, 2017 at 9:13 PM
    • Like Like x 1
Share This Page
