Harry Mash
"Turbofan"
- May 3, 2004
any of the experts make a chip for 50 pph Delphi injectors that will pass Calif. smog test ? I would want it to run closed loop at idle; have enough EGR to keep NOX within specs; enough fuel to run 23 lbs.. boost at full throttle on 91 octane gas with alcohol;lock the TCC at 60 mph at normal acceleration and turn on the fan at 175 degrees. Is it possible to have a clean air tubo Buick with 50 pph injectors, or am I asking too much.
