Cam choice decision ?
JeffW
Whistlin' on by. Wossshhh
I'm about to add several upgrades and haven't fully decided on a cam.
I don't really want to step up to a roller cam right now, so I've pretty much narrowed it down to 2 different hydraulic comp cams with lifters. Either a 206/206, or a 212/212.
Here are the other upgrades, which will all be installed at the same time:
You can see my current setup in my sig.
Here are the upcoming mods:
Hi Flow ported heads from Nick Micale
T&D 1.6 roller rockers (and taller valve covers)
RJC Power Plate
New double roller timing chain/gear
60# injectors from Mike Licht
Extender chip for injectors, 96 oct, 21/19 timing
6.2 eprom to upgrade translator from 4.1 version
Thanks,
Jeff W
I just went with a SpeedPro 204/214 cam. Not to start a fire here but I have read that quite a few comp cams have ended up all over the motor. This is just what I have read, so all of you Comp cam fans, I'm not picking on you.:)
Ray
