Cam question
Fasstcars
When only boost will do
I picked up a ttype with a knocking motor so I picked up another motor from Jim(vsix)--thanks again. I also have new injectors and a chip. I want to change the cam before I put the motor in. I've heard the the speed pro 204/214 is a good choice and also a 210/214. The car will have 50lb injectors, chip, whatever cam, Lt1 springs and ported heads. I will still have the stock turbo for now but plan on changing the downpipe and going to bigger exhaust. This will get my feet wet with the car then I can rebuild the motor thats in the car now thats blown and add some more parts. My goal is to hopefully end up in the mid 12's with these bolt on's. Any cam advice would be great and were to purchase as well. I know the speed pro's aren't to expenseive. Thanks
Since I'm new to the list I don't want to be a pest but surely some people have cam recommendations. Mainly I'd like to know who carries speed pro parts so I can check into the 204/214 cam. They are pretty inexspensive and just need a direction to look. Thanks Steve
Your PM box is full so I shot you an email. I'll take the cam though. I shot you a couple of other questions. Thanks Steve
Just letting you know Matt (49blues) is a very good guy to deal with. you won't go wrong.
Ray
Thanks 87GN and 6 you guy's have been a great help. I emailed Matt about the cam and haven't heard back so we'll see. I should be able to find one either way.
