Cam sensor interrupter ring
HellOnWheels
HellOnWheels
The interrupter ring tab keeps searing off in the cam sensor, the last one that sheared I had pinned as well as installing the screw using locktite. What is the heck is causing the tab to shear off and what is the fix??
HellOnWheels
cam sensor ring
The only thing that can cause that kind of problem is if the shaft bushings are worn out. Check side to side play and you will probably find to much movement. Hope that helps
