Doug Jacobson
Altitude Compensated
- May 24, 2001
Ok, getting ready to fire a fresh motor tonight and the time came to set the cam sensor. well........... since gnttype.org is down I couldn't get the method I've always used to succecs. Heres what I did from memory, correct my wrong step please.
1. Cut a 1.45" piece of masking tape,
2. Put masking tape on the balancer counter clockwise from the timing mark.
3. Rolled it around to the length of the tape After TDC, or 0 on the plastic timing peice. Withthe engine on TDC #1 (and I KNOW it was on #1)
4. Probed the middle wire of the cam sensor with meter.
5. Rotated the can sensor clockwise until voltage dropped from 5v to 0v
6. Locked it down
When trying to start the car it would crank hard. I loosened the sensor and rotated it some more clockwise and it fired and ran good enough to break in the cam. After thinking for a while I've dug up a tidbit more information from the back of my head that is telling me that I need to rotate the sensor counter clockwise when checking for the voltage to drop.
So old pros, which is it? Clockwise or Counter Clockwise?
Thanks, Doug J
6. Locked it down
Thanks, Doug J
