Cam sensor
Quick Turbo V6
Define stock!
Has anyone had a problem with sheering off the little nub on the cup thats inside the cam sensor? I have had this happen twice now. It seems to happen over 4000 RPM's. The oil pump seems to rotate fine. The sensor does not seem to get hung up, it rotates fine also. I did not change the housing when this happened the first time. So im thinking that might be what's wrong. Any ideas???
Thanks,
Scott
