Ok... fall out of the chair now..lol...
Yea.. I've never put Alky on anything. (yet) lol...
Here is the setup..no real black majic...
Stock block,crank,rods. Steel caps.
JE pistons (full float)
Out of the box non ported GN1 heads
Stock intake cleaned up on the inside
Accufab throttlebody/upper plenum
TTA front mount CAS
.72mm turbo
218/218 cam (non roller)
200R trans with 3000stall
9" ford with 3:50 gears,detroit locker/35spline axels good center section.
The car started out running 12.60's and with tuneing at the end of the year it was consistant low 11's. (gota love that FAST system)
It took awhile for the owner (then) to learn how to launch and me to get the Fast System dialed in.
Funny story... we had a 3" down pipe on it and all we could build for boost was 18lbs. No matter how much we cranked the actuator. So, I kept putting more ignition timing in it since we got no knock. The car kept getting faster and faster each pass till that night at US41 we got our 10.92 pass. We got home and later that week I made a 3.5" down pipe down to the duel 3" system that was under the car. Never touched the actuator rod..... Paul took the car around the block and came back with a shocked look on his face.
I was like.. .what??? he said I had to do a double check on the boost gauge.. I said... why? He said it was at 26.5psi now!
The old hacked up...temporary down pipe had been holding us up.(back pressure)
He took the engine and trans out of the Camaro two weeks later and put it in his very nice GN.. And left the Camaro Chassis sit... and I ended up buying it from him and it's awaiting my engine...
Whew.. Sorry for the history lesson but that's how it went to reach our goal.
Hope that sheds some light on how we got there...
Just takes patience and tuneing to get there safely.
Don't get greedy and look for that 10sec pass on the first time out. Your bound to be tearing it back apart.
Hope that helps..
Scott~
