Cams!!!
Ernie660R
Has anyone tried this cam yet?Camshaft, 264HR, High Energy, Hydraulic Roller, 264/264-212/212-.504/.504-110
It sounds like a good cam to me but wanted some input from you guys first.:)
Well wanting to accomplish high to mid 11 seconds et. I have a few other things to go with this, 42.5lbs injectors, polished and ported heads along with the intake, 3 Inch dump pipe, etc.
I'm installing one now in a customers engine. Looks like a really nice unit. Think it may be overkill for what you want unless your just looking at the rollers. If not go with a 204-214. I can get you one for $80. Thanks,Frank
very good cam run that in conjuntion with a rev kit this will allow you 500-800 more RPM and take some load off the lifter it common to run the rev kit even though you are running a hydraulic roller it will complment your heads nicely, good luck in your build up.stay safe.AL
