SteveRacer
- Mar 29, 2003
SignUp Now!Yes it is early. I just checked the one in my engine i just assembled and it was the same part#. Mine came out of a 1978 3.8 turbo.turbofish38 said:That looks like the correct crank. The FWD 3.0 crank will have a different flange. From what I can tell it's late 70's vintage from the casting number. It was superceded by the 877 casting that most of us are familiar with.
The one is his pic has the rolled radius on the rod journals. The only question would be how much its been turned too much already, or if its cracked, welded, or bent.Nick Micale said:You cannot go by part numbers, or just looking at a crank to determine if it is from a turbo motor or not. If you take your fingernail and check both ends of the rod journals and can feel the rolled fillets [actually a depression], you can then feel safe it is a turbo crank.
If the rod journals have been heavily machined, it would next have to be measured to determine diameter before it is used.
The GM part number, and casting number, for 1986-7 turbo and non-turbo cranks are the same.
