Can someone help me identify an injector
Steve
I recenlty came up with a set of injectors and the guy I got them from said he thought they were 50's but I am unsure so I wanted to check. They have the numbers 621037 and 03165aa on the larger band and 1937 further up. They have green band and two holes at the bottom. I think they are 38's but I am unsure. Thanks for the help
Steve
Delphi / Lucas
37 lb / hr. Disc Injectors
Part Number Delphi D3165BA (Lucas old 5203002, Lucas New 621037)
Static Flow Rate: 37.27 lb/hr @ 43.5PSI (300kPa) or 282gm/min
Dynamic Flow Rate: 8.42 gm/pulse - 2.5ms pulse width and 10ms repetition rate
Coil Resistance: 15.9 Ohms / High Impedance / High-Z (No ECM driver modifications required)
