can you make a power master brake pedal into a vacuum one
grass doctor
Dream Catcher
TurboBuick.Com Supporter!
can this be done by just drilling hole or is the angle wrong too
My friend just converted his over to vacuum, drilled a hole, installed a new pin, no problems, we just did a 150 mile run Friday nite, and he had no issues. My car, I went to a pick and pull and got a pedal for $3.00
cool I have three power master pedals was curious thx for input
The angle is set by the master cylinder mount or the firewall stamping. The firewall is stamped for a booster with a 3:1 ratio. The bracket for the PowerMaster adapts the firewall for the 6:1 ratio the Powermaster needed (or manual).
Yeah. My pedal has a hole in it where I put a pin for Vacuum about 30 years ago. Then I went to Hydroboost which has the same pin location as the Powerdisaster and after 160K+ miles will never go to anything else. Waaay better than vacuum and much better than a good (rareley seen on cars driven alot) working Problemmaster.
