Went to the track. I am extremely frustrated. My car is getting slower not faster. First run was a 4lb boost launch with a 2.38 60ft (on slicks). 14.08 @ 103mph. It went down hill from there. I could only build 5lbs on the line, period. I ran 22lbs in the run but launch is killing me. That run had 0 Knock and 800 o2's. I don't get it. Last time out I ran horrible 13.3 @ 99mph with 2.1 60ft. Figured I would launch harder to do better. The harder I tried the worse the car got. I ran 14 sec on 3 runs and 2 others I let off because I got knock. Thought maybe I cracked the header, so since it is night I checked it a few minutes ago. Not cracked, although I can see about 3 of the spark plugs sparking ever so slighty. I don't know if they came loose but I will check them tomorrow to make sure they are tight in the heads. What the heck is up with my car. 22lbs of boost, 110 fuel and I run slower than it did stock. About ready to give up racing this thing. It is 12 second car and I can't get in the 12's. Somebody help with suggestion on possiblilities.
