The IC hose just won't stay on when boost gets above 27psi.
I just put on new hoses and T-bolt clamps tonight and tightened them down goooood! Up to around 27psi it's all good. When I up the boost to 29psi the hose won't stay on the TB..
I have a couple of ideas:
1. Can/Has anyone weld a larger lip on the end of the TB so the hose has something to grip?
2. Has anyone created a mechanism to pull the up-pipe towards the TB to keep it from moving away from the TB?
There was mention in the below post that using a stiffer hose helps, and I think this is a good idea but a stiffer hose may not grip the TB good enough either..
http://turbobuick.com/forums/threads/up-pipe-keeps-blowing-off.381417/
Help...
Kevin
Help...
Kevin
