Car dies
smallv6
Still in Block Learn Mode
First off I tried to do a search on this problem and found nothing.
I decided to try the new trans+ setup and turned the first switch to run 2% leaner at idle, This is the only switch I turned and the connections have been double and triple checked. Also all 1-4 switches are where bob bailey set them and are correct.
The car dies as soon as I turn the switch to run 2% leaner.
If I go the other way to add 2% the car smokes like a pig.
Anybody know what is going on here?
Fuel pressure at 45
blm's at 126 (idle)
TPS at .47 (idle)
:confused:
Is your chip programmed for anti theft?? If so - give your chip maker a call & he'll help you get it sorted out. Sorry - no directions on the web.
