this problem happened last weekend. i drove my t-type home and parked it -- it was running just fine. the only things i did to it was remove my fuel pressure gauge (it broke, and one of the fittings was leaking), and re-install my schraeder valve in its place. when i tried to fire the car up, it wouldn't. it just cranks, and occasionally chugs a little like it is about to kick over, but never quite does. i pulled the spark plugs, and they were wet with gas. i dried them and tried it again, but the same thing happened. i made sure the rail is getting pressure -- i depressed the schraeder valve while someone turned on the pump to make sure no air was in the system. i also thought it might be spark... i just replaced the coil pack with one of an unknown brand from NAPA. however, all coils test at 11.6 ohms, which is apparently within tolerance. any other ideas what could have gone wrong while the car was just sitting there? any other things to test? i'm about out of ideas here. i sure hope its not anything in the ECM... it is pulled out of its housing and is sitting on the passenger side floorboard with the EPROM cover off. i hope one of my passengers didn't kick it while we were doing donuts on the ice that night!
