car won't start
Mr-SShadow
Hey guys,
I changed my head gaskets and also replaced my water pump and timing cover and upgraded to a higher flow oil pump.
I got everything back together and now it won't start. It turns over, but nothing. I checked the fuses and they're good. The injectors aren't getting power and same with the fuel pump, also no fuel pressure, but everything seems to be connected right.
I'm still learning this engine so any help is appreciated. Only other thing I can think of is if the previous owner tapped into the wiring harness for power and/or used an inline fuse I can't find.
thanx
did you plug the injector harness back in? did you re install the ground's to the back of the passenger side head? did you plug in the ignition properly? etc. etc. etc.
You don't..
mention if you have a hot wire kit, or home made, to the fuel pump? the in line fuse could be in the trunk, by the connector or by the rear of the gas tank, near the pump connector. Generally there is a wire, which would be a second wire, attached to the alternator output post, to supply juice to the fuel pump. an inline fuse could be located near there?:confused:
